Upgradation issue from 4.2.3 to 7.1.5
sasanka.pathi
Hi, i am trying to upgrade from 4.2.3 to 7.1.5. When ever i tried to load the Back up of 4.2.3 to 7.1.5 its give me an error. So here is how i am doing
On WIndows i have core mini sftp server and in that following is hte configuration:
Userr name: sashank
password : cisco
port : 22
root path: c:\cisco\DMABackupWithWarnings04-07-10#4-23.tar
so this is the call manager configuration and on the CUCM configuration as follows:
remote server name: 10.10.10.249
remote file path:/cisco
remote file name:DMA BackupWithWarnings04--07-10#4-23.tar
remote login id: sashank
remotepassword: cisco
But i am getting an error mesage that /cisco is not found or cannot be used. What should i do now?
Jaime Valencia
The error is absolutely right, you're referring to a non-existant folder.
If your root is c:\cisco\ then you just need to use a /
If your root is c:\cisco\ AND you have the file in c:\cisco\cisco\
THEN you would tell CUCM to look into /cisco
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Hi I fixed the issue by keeping /. in the path and it worked like a charm. Thanks for your help.
