UPGRADATION WITHOUT DOWNTIME
Cisco Unified Communications Upgrade & Virtualization
 we are looking forward to upgrade its existing Unified communications infrastructure based on Cisco on a virtualized environment. The current system is based on the following: i) Call Manager v8.5 ii) Cisco Presence v 8.5 iii) Cisco Contact Center Express v8.5 iv) Unity Connections v9. we are required to migrate systems i, ii & iii currently running on MCS hardware without downtime to the Virtual environment and upgrade it to the latest stable release of v10 and integrate i, ii, iii & iv.
Is it possible to upgrade without downtime? what are the diffculties i will face while migrating?
which is the best & suitable way to migrate?
Help on this taks!!
VIP Purple
Hi Siva,You need to build the
Hi Siva,
You need to build the new system in offline /non-production mode since IP addresses would remain same.
Further, firmware of IP phones on latest CUCM 10 also needs to be looked.
I suggest upgrading phone firmwares in existing CUCM 8.x to latest available versions so as to have minimal downtime.
regds,
aman
Aman,How abt migration steps?
Aman,
Dear Aman,As u gone through
Dear Aman,
As u gone through Ayodeji steps,he told to give diffrent ip address
VIP Purple
Hi Siva, I am also in SYNC
Hi Siva,
I am also in SYNC ith AOK provided if u can do that since PCD is an excellent tool to do this.
Also, if u do that your donwtime would be almost negligble since Old MCS would keep on working and new VM should power ON when u are ready to put in production.
If u keep different IPs for CUCM 10, u just need to change in TFTP option 150  [point to new TFTP CUCM server] in DHCP pool.
regds,
aman
Aman,Installing cucm 8.6 into
Aman,
Installing cucm 8.6 into vm environment,while upgrading to version 10..should i required any
upgrade licenses
VIP Purple
Yes. U need licenses for CUCM
Yes.
U need licenses for CUCM 10 which is PLM[Prime License Manager].
Prior to migration, upload any un-used PAKs, run LCU [license count utility] which is downloadable from Cisco.this would be csv file consisting of details of Basic/ UCL enhanced/ enhnced plus , CUWL standard, IP address of Publisher etc
After successful migration to CUCM 10, generate the file from PLM . Send this and LCU report to licensing@cisco.com to get the desired licenses.You have a grace period of 60 days after u do successful migration to CUCM 10.
Upload the recived file from licensing team.
https://supportforums.cisco.com/document/12229791/understanding-cisco-prime-license-managerplm
refer the link for PLM
https://supportforums.cisco.com/document/12229461/licensing-cucm-10x-using-cisco-prime-license-manager
regds,
aman
AmanThis procdedure is clear
Aman
This procdedure is clear,my doubt installing cucm 8 in UCS should required any temprorary licenses for upgrade to 10
VIP Super Bronze
No, you don't need any
No, you don't need any licenses. You license the cluster after upgrading to 10.5. Ensure that you use the cucm10.5 ova for the 8.5 install on UCS because you will be later migrating to 10.5 This will save you the need to change the vm settings later on
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Purple
[+5] to AOK. regds,aman
[+5] to AOK.
regds,
aman
Ayodeji,Wow really good
Ayodeji,
Wow really good information,sure i will deploy with CUCM 10.5 ova ...
After upgrading  Call Manager
After upgrading  Call Manager in ucs platform remaining servers should i upgrade randomly or i should follow any procedure for   Cisco Presence ,Cisco Contact Center Expres, Unity Connections
VIP Purple
Hi Siva, Unity connection
Hi Siva,
Unity connection should be done at last.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Supported Version Combinations for Cisco Unity Connection 7.x and Later with Cisco Unified Communications Manager
7.x and Later
10.5, 10.0(1), 9.1(2), 9.1(1), 9.0(1),8.6(2),8.6(1),8.5(1),8.0(x), 7.1(x), 7.0(x), 6.1(x), 6.0(x), 5.1(x), 5.0(x)
For CCX, refer the link but do check your exact existing CCX version .Should be 8.5(1)SU4
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5(1)
for presence,refer the link but do check your existing version.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/10_x/CUCM_BK_CD1DB914_00_compat_matrix.pdf
regds,
aman
VIP Purple
If u install CUCM 8 in UCS,
If u install CUCM 8 in UCS, then u can request   temp/permanent licenses.the same u can get from licensing team.This would be License MAC.
Now, since u are upgrading finally to CUCM 10, then,u can request permanent CUCM 10 licenses after successful migration.This procedure is if u do not follow PCD.
In case , if u go with PCD then, u would get grace period of 60 days.
regds,
aman
VIP Super Bronze
There are two ways this
There are two ways this upgrade will be achieve without down time.
1. You will need to use different IP address for all your servers. This has its own headaches. For this to happen you need to do the ff:
a. Install cucm, cups 8.5 on a stand alone network. Make sure its stand alone.
b. Restore your production DRS backup to the new install
c. change the ip address of your servers to new ip and put it on your production network. NB: when you change you ip there are other things to consider. You will need to change the ip on the other applications too..eg unity connection, CUPs etc
2. Upgrade all your servers on VM to 10.5. Please refer to the link below on best practices to upgrade to 10.5
https://supportforums.cisco.com/discussion/12313756/cucm-862-upgrade-cucm-105
3. After your upgrade is complete, you will need to go and change the default firmware load on your server to the old firmware load running on your cucm 8.5. If you don't do this when your phone registers to the new 10.5 cucm cluster, they will upgrade their firmware and this will lead to downtime.
4. finally change the tftp address on your dhcp to point to the new 10.5 cluster
5. Go to your old cluster and reset all the phones, they should register to the new cluster with minimal down time..
My suggestion is to advise your customer that this is a major upgrade and that there will be down time even if it is small.
Ayodeji,How abt contact
Ayodeji,
How abt contact center migration?
Ayodeji,Should i required PCD
Ayodeji,
Should i required PCD tool for this upgradation or i can upgrade directly from 8.6 to 10.5?
Which is the best practise?
VIP Super Bronze
PCD is a great tool. Yes it
PCD is a great tool. Yes it can be used for the upgrade and migration.
Please take some time to learn how to use it here..
https://www.youtube.com/watch?v=JzG4kz1_hL4
You cant use PCD for contact center but you can use it for CUCM, unity and IM and P. The video will show you step by step how to use PCD.
For  contact center, please refer tothe upgrade guide and read through the documentation
As u mentioned i need to
As u mentioned i need to install standalone servers,how about upgrading redundancy servers!
VIP Super Bronze
I said install in a stand
I said install in a stand alone network. Install the new cluster in a non production network. This is because you will need to install the servers with the ip address of your current cluster and if you put it on a production network you will get ip address conflicts and bring down your cluster.
VIP Purple
Yes, u can use PCD since u
Yes, u can use PCD since u are migrating from MCS to VM HW.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118318-config-cucm-00.html
regds,
aman
172
