Upgrade 2620XM
i have 2620XM with 48F and 256D only no any more
i want to run E1 by module VWIC2-1MFT-G703
if i buy PVDM-12 ?   is it enough to run it , am i need any additional module to run PVDM-12 , how many chanel PVDM-12 give me?
ibrahim
best regards
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Upgrade 2620XM
You will require a NM to hold the PVDMs
Please rate this post if was helpful
Walter Solano
CCNA Voice
Cisco UCCX Specialist
Re: Upgrade 2620XM
Hello  Ibrahim
The best way to calculate the amounth of PVDMs that you need to acomplish certain tast is using the DSP calculator.
http://www.cisco.com/pcgi-bin/Support/DSP/cisco_prodsel.pl
Also this documents will give you better information about PVDMs
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016e845.html
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080a7af82.shtml
Walter Solano
CCNA Voice
Re: Upgrade 2620XM
thank you ,
but i need to know if i must have NM-HDV module or i can applay PVDM -12 on  board ,  are there slot in board to applay PVDM or must have NM-HDV?
ibrahim
Re: Upgrade 2620XM
Walter Solano
CCNA Voice
Re: Upgrade 2620XM
Can i hold PVDM-12 in AIM slot ?
Are 2800 also recuired module to hold PVDM2-8 or it has 2 PVDM2 slot ?
thanks
ibrahim
470
