Upgrade 5.1(3) to 6.1(2) CUCM
Hi all,
how to download the patch file for upgrading 5.1(3) to 6.1(2) from cisco.com
Hari
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Upgrade 5.1(3) to 6.1(2) CUCM
Hi Hari,
This upgrade *** will require you to order the Media Kits and License via PUT;
Upgrade Paths To Cisco Unified Communications Manager 6.1(2)
You can upgrade directly to Cisco Unified Communications Manager 6.1(2) from:
•4.2(3x)
•5.1(2x)
•5.1(3x)
•6.0(1a)
•6.1(1x)
Caution: Use the ISO files that are mentioned in the "Upgrading from Cisco Unified Communications Manager Release 6.0.(1a) or higher to Release 6.1(2) by Using the UCSInstall File" section for upgrades from 6.1(1x)only.
Upgrading from Unified CM 4.x and 5.x
***If you are upgrading from 4.1.3, 4.2.3, 5.1.1, 5.1.2, or 5.1.3, use the Product Upgrade Tool (PUT) or the PUT that is for registered customers only to obtain a media kit and license or to purchase the upgrade from Cisco Sales.
To use the PUT, youmust enter your Cisco contract number (Smartnet, SASU or ESW) and request the CD/CD set. If you do not have a contract for Cisco Unified Communications Manager, you must purchase the upgrade from Cisco Sales.
For more information about supported Unified CM upgrades, see the Cisco Unified Communications Manager Compatibility Matrix at the following URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_device_support_tables_list.html
From these good release notes;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp396032
Hope this helps!
Rob
EDIT: Java, you must be up early and having some strong coffee this AM. Great work my friend ;-)
ROCK ON!
not available at CCO, you need to order the upgrade kit
The only one available is strictly for upgrade from 6.0(1)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Hari,
•4.2(3x)
•5.1(2x)
•5.1(3x)
•6.0(1a)
•6.1(1x)
Hope this helps!
Rob
ROCK ON!
129
