Upgrade assistant for 5.X?
Is there an upgrade assistant, not the DMA, for upgrading to 5.X? I only saw ones for 4.3.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Upgrade assistant for 5.X?
Hi Chris,
The Upgrade Assistant Utility Version 4.3.1 is to be used for 5.x upgrades. Have a look;
Using Cisco Unified CallManager Upgrade Utility 4.3(1)
The Cisco Unified CallManager Upgrade Utility, a nonintrusive tool, detects the health of the servers in the Cisco Unified CallManager cluster before you perform an upgrade to Cisco Unified CallManager.
This version of Cisco Unified CallManager Upgrade Utility replaces previous versions of Cisco Unified CallManager Upgrade Utility, Release 3.3(5), Release 4.0(2a), Release 4.1(2), Release 4.1(3), Release 4.2(1), Release 4.2(2), and Release 4.2(3). Cisco Unified CallManager Upgrade Utility 4.3(1) adds support for multiple version upgrades. Use Cisco Unified CallManager Upgrade Utility, version 4.3(1) or later, to detect the health of your servers before you upgrade to Cisco CallManager Release 3.3(5), 4.0(2a), 4.1(2), 4.1(3), 4.2(1), 4.2(2a), 4.2(3), 4.3(1), 5.0, and 5.1.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_upgrade_guides09186a00807a2395.html
Hope this helps!
Rob
1 REPLY
Hi Chris,
From this doc;
Hope this helps!
Rob
104
