Upgrade Call Manager 4.1 for 7.0
Hello! Can someone tell what i have to do if i want to upgrade Call Manager 4.1 for 7.0? and i've got this MCS (MCS-78251-3.0-1PC1), is it compatible with call manager 7.0? where can i got some web information about this? Please help me! Thanks very much
Re: Upgrade Call Manager 4.1 for 7.0
Hi Joao,
You can upgrade from CCM 4.1 to CUCM 7.0(1) using Data Migration Assistant (DMA). See Tab 4 in http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40014.
You MCS is compatible with MCS-7825-I3-IPC1.
Other upgrade information you can find at http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html
Release notes forr CUCM 7.0(1) at http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html
Hope this help
Regards Miroslav
Hi Mirolasv! first off all thanks for your help! but in this link (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html) i cant find any information about the compatibility of my MCS with CUCM 7.0, i only find information until CUCM 6.1. Can you or someone help me please? thanks again
Hi Joao.
You are right ... BUT ... original CUCM 7.0(1) apliance is almost same as yours MCS see http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/ps7299/product_data_sheet0900aecd805efb09.html
According to release notes for CUCM7.0
"Be aware that some servers that are listed in the Cisco Unified Communications Manager Software Compatibility Matrix may require additional hardware support for Cisco Unified CM Release 7.0(1). Make sure that your server meets the minimum hardware requirements, as indicated in the footnotes of the Cisco Unified Communications Manager Software Compatibility Matrix. Cisco Unified CM requires a minimum of 2 GB of memory, 72 GB disk drive, and 2 GHz processor. "
So I think you MCS is OK ;o)
194
