Community Member
Upgrade Call Manager from 4.1(3) to 5.1.2
I am trying to upgrade call manager and I get an error message saying unknown platform. According to Cisco my server is compatible. Any help would be appreciated. The server is MCS7825H3 IPC1
Re: Upgrade Call Manager from 4.1(3) to 5.1.2
I do not see that server as a valid platform for CUCM 5
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd805e6fac.html
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Thanks for the quick response. I was looking at this document and it says that this server is a valid server. Can you clarify.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
think you're hitting this bug
CSCsj57609
Externally found moderate defect: Resolved (R)
Back port H3 and I3 servers to 5.1 release
On the release notes for CUCM 5.1(2b) it is stated that until that version it is included
support for servers MCS-7816H3, MCS-7816I3, MCS-7825H3 and MCS-7825I3.
java
123
СоздатьДля создания публикации, пожалуйста в систему
