Community Member
Upgrade Call Manager
Hello All,
our company is planning to upgrade Cisco Call manager 5.0 to version 8. Can you please help me out what the procedure will be. Or also what the steps i need to follow to upgrade from 5 to 8.
Purple
Hi ,
For upgrading call manager from version 5 to 8 , u need to consider the following steps:
a. you need to have valid ESW and UCSS contract since this would be a major upgrade.
b. Check for existing Hardware since DRAM and HDD requirements are  different for version 8.0(3) and above.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
c. you also need to check the software compatibility matrix.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
Hall of Fame Super Silver
In addition to good answer from Aman (+5), please follow the upgrade guide which details all the necessary steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_6_1/cucos/iptpch7.html
You can also search this forum for similar threads as this is quite often asked.
HTH,
Chris
142
