08-29-2007 04:43 AM - edited 03-14-2019 11:16 PM
Hi, hope you can help. I am currently planning an upgrade from 3.3(4) to 4.2(3). The customer has several SRST gateways running IOS 12.3(4)T3. Are there any upgrade dependencies on the IOS/SRST version currently running on the gateways for this upgrade?
08-29-2007 05:34 AM
The recommended and test IOS with CM 4.2(3) is 12.4(4)T. Though you can use the current version, but it is always recommended to be atleast at the IOS which is recommended and tested. Please check Compatilibility Matrix for more details regarding the same.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/prod_software_versions_comparison.html
Hope this helps
08-29-2007 05:57 AM
Thanks for your reply, this info is greatly appreciated.
