Upgrade CCM 3.3(4) to CCM 4.2(3) - SRST Query
Hi, hope you can help. I am currently planning an upgrade from 3.3(4) to 4.2(3). The customer has several SRST gateways running IOS 12.3(4)T3. Are there any upgrade dependencies on the IOS/SRST version currently running on the gateways for this upgrade?
Gold
Re: Upgrade CCM 3.3(4) to CCM 4.2(3) - SRST Query
The recommended and test IOS with CM 4.2(3) is 12.4(4)T. Though you can use the current version, but it is always recommended to be atleast at the IOS which is recommended and tested. Please check Compatilibility Matrix for more details regarding the same.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/prod_software_versions_comparison.html
Hope this helps
Thanks for your reply, this info is greatly appreciated.
110
