Upgrade CCM 4.1(3) to 6.1(2) - DMA
Hi All,
<br />I cannot seem to find any definitive answers to the following, When you upgrade from 4.1(3) to 6.1(2)and run the Data Migration assistant are the users personal address book setting retained and also are the custom IP phone services retained and carried over to the 6.1(2) build?
<br />
<br />Any suggestions greatly appriciated.
<br />
<br />Thanks
<br />Bryan
<br />
1 REPLY
Re: Upgrade CCM 4.1(3) to 6.1(2) - DMA
there were some issues but info should be migrated
CSCso77371
DMA DirExport failed to migrate PersonalAddressBook
Symptom:
Migration of PersonalAddressBook fail and DMA warnings for PAB were observed.
Warning: PersonalAddressBook: EndUser
OU=PersonalAddressBook,OU=userid_info,OU=user_info,OU=CCN,OU=Cisco,DC=m not found. Invalid user.
PAB-DN=CN=xxxx1127877735204,OU=PersonalAddressBook,OU=xxxxx_info, OU=user_info,OU=CCN,OU=Cisco,DC=mail,DC=abc,DC=edu,DC=au
Condition: Either the user does not exist in the directory or has been tagged invalid
In DirExport, fast dial index of the fast dial entries become all 0. The fast dial index are correct in ciscoccnocFastDialEntry.csv file but in PersonalPhoneBook.csv file, the index are all 0, this caused the fast dial entries not showing up on the phone but it is showing up in the ccm user page
Conditions:
Callmanager integrated with active directory
Workaround:
No workaround
CSCso77371
Fixed-In versions (DMA):
6.1(2.21)
7.0(0.243)
7.0(0.504)
7.0(0.188)
7.0(0.39700.83)
6.1(2.9901.18)
6.1(2.9901.92)
7.0(0.39700.160)
6.1(2.79)
7.0(0.503)
7.0(1.10000.10)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
no custom stuff is migrated with DMA
java
if this helps, please rate
java
www.cisco.com/go/pdi
151
