Community Member
Upgrade CCM 5.1.3 to CCM 6.0.1a ??
Can anyone point me to a document that describes, step by step, how to upgrade a CCM 5.1.3 server to CCM 6.0.1a?? Is it possible?? Do you need to get updated licenses from Cisco?? I have already searched cisco.com and came up with nothing definitive.
Thanks in advance,
Tony
Re: Upgrade CCM 5.1.3 to CCM 6.0.1a ??
This is not a supported upgrade path. Once you go to 5.1(3), you will need to wait for 6.1 release to upgrade.
Hall of Fame Super Red
Hi Tony,
In the attached Compatibility Matrix the Note was added 11/7/2007 that indicates that inability to move from CCM 5.1.3 to CCM 6.0.1;
CCM Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.xls
This link shows the upgrade from 5.0.4 or 5.1.1 not 5.1.3
Cisco CallManager Upgrade Paths
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008086cc7c.shtml
Sorry about that :(
Rob
Edit: Adam, you are too fast for my Baboon like typing skills :)
Community Member
So how about mine: Active Version: 5.1.2.3000-2?
Do I have to switch back to Inactive Version: 5.0.4.2000-1 ?
Thanks.
5.12b should be good to go.
Silver
I was told you even have to wait until 7.x- is this true ?
128
