Upgrade Cisco 1861 router
Hello All ,
Please suggest Supported Images for Upgrading Cisco 1861  IOS Software Release 12.4(11)XW f
should be available more features like VPN & All features that required for VOIP
Default image:c1861-spservicesk9-mz
SP Services K9
c1861-ipvoice
IP VOICE
c1861-entservicesk9-mz
ENTERPRISE SERVICES K9
c1861-advipservicesk9-mz
ADVANCED IP SERVICES K9
c1861-adventerprisek9-mz
ADVANCED ENTERPRISE SERVICES K9
1 ACCEPTED SOLUTION
Re: Upgrade Cisco 1861 router
Correct that is the one if you want everything.
Are you interested in the features within each of those? If so here's a comparision diagram: http://www.theitstuff.com/files/2008/12/cisco-ios-feature-diagram-300x207.jpg.  If there are certain features you're looking for you can also try using the Software Advisor: http://tools.cisco.com/Support/Fusion/srselectmdf.do.
Thanks for your reply,
Means I should get c1861-adventerprisek9-mz for getting All features ?
Vikrant
210
