upgrade CME 3.2 to 4.0
If I want to upgrade my CCME from 3.2 to 4.0, what would be the procedure???.... is it the same like we upgrade IOS on the router ??...
Also will CCME 4.0 support SIP phones ???
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: upgrade CME 3.2 to 4.0
It is only IOS upgrade plus the GUI files if you use it.
For third party SIP phones just configure username and password under voice register pool to be the same as in the phone. The required mac address does not matter and can be all zeros.
What router do you have? Have you checked ram and flash required for CCME 4.0 / IOS 12.4(11)T ?
Third-party SIP phones are not offically supported, but known to work.
I have Cisco 2851 router and yes I checked the RAM and falsh required for CCME 4.0...
My question is that is there any procedure for upgrading the CCME or similar to the IOS upgradtion on router...
Any steps you can provide for configuring the SIP phones, if you have done so...
130
