Community Member
Upgrade CUCM 4.1.3 to 6.1.4a DMA version
I will upgrade from CUCM 4.1.3 to 6.1.4a should i use DMA 6.1.4 or DMA 6.1.4b?
Best Regards,
MC
1 REPLY
Hall of Fame Super Red
Re: Upgrade CUCM 4.1.3 to 6.1.4a DMA version
Hi MC,
I would recommend using DMA 6.1(4b) due to the defects that are resolved
in this version
Caveats That Are Resolved in Data Migration Assistant 6.1(4b)
The following defects are resolved in the 6.1(4b) release of DMA.
•CSCsy07560 DMA does not migrate ICD Extension.
•CSCtb25098 The DMA process increased in time required due to the fix introduced for the defect CSCsy07560.
•CSCsz63731 Replication failure in Unified CM 4.x after DMA failed export.
•CSCsz17031 Upgrade failed with no reported user error file message.
New and Changed Information for Data Migration Assistant 6.1(4b)
DMA 6.1(4b) release does not contain any enhancements or feature updates. This release comprises strictly a maintenance release.
Release Notes for Data Migration Assistant Release 6.1(4b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/6_1_4/dma-rel_note-614b.html
Hope this helps!
Rob
257
