upgrade CUCM 5.1.2 to CUCM 6.0(1)
Anyone seen a document for this? Is it really as simple as it sounds for using the
cisco-ipt-k9-patch6.0.1.2000-3.tar.gz.sgn
file, let it load, then reboot and cross your fingers?
Thanks!
Hall of Fame Super Silver
Re: upgrade CUCM 5.1.2 to CUCM 6.0(1)
You got it, the upgrade procedure is just like any other patch upgrade from 5.X.
HTH,
Chris
Thanks much. Have you been using any other builds other than the one I listed?
139
