upgrade CUCM 6.1.5(su3) to 8.5.2
I was wondering if the CUCM 8.5 is installed on the inactive partition of the CUCM when upgrading from 6.1.5, or if the upgrade is overwriting the CUCM 6.1.5 (like the upgrade to 8.6).
Thanks a lot,
Best regards,
Antoine Meunier
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Antoine,
Yes you still have the inactive partition which is your 6.1.5 in this case..
here is the release note
Step 10 Perform one of the following procedures:
a. To install the upgrade and automatically reboot to the upgraded partition, choose Reboot to upgraded partition. The system restarts and is running the upgraded software
or
b. To install the upgrade and manually reboot to the upgraded partition at a later time, do the following steps:
1. Choose Do not reboot after upgrade.
2. Click Next.
3. The Upgrade Status window displays the Upgrade log.
4. When the installation completes, click Finish.
5. To restart the system and activate the upgrade, choose Settings > Version; then, click Switch Version.
The system restarts, running the upgraded software
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_5_1/cucm-rel_notes-851.html#wp1840219
Pls rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Antoine,
or
2. Click Next.
Hi Antoine,
Is its a linux to linux upgrade, it doesn't overwrite the active partition. The next version is always installed on the inactive partition, the moment when you perfrom switch version, this new version gets enabled and makes this partition as active partition.
Hope it helps.
Anand
Please rate helpful posts !!
497
