UPGRADE CUCM 8.5 IN A VMWARE to 8.6 VERSION
Hi to all
i HAVE a CUCM 8.5 cluster mode in a virtual Environment RUNNING ESXi 4.1..(UCS210)
I know that i have to follow the structure from the below link
https://supportforums.cisco.com/docs/DOC-16898
BUT what happen with the ova file..i have to create a new virtual machine with the ova file for cucm 8.6?
what is the correct Procedure for (cucm 8.6 upgrade) in a virtual Environment
Notes :
I found from here OVA Template Details for Unified CM Release 8.5&8.6 that the only different from these ova files are the reservation
vCPU Cores (= Physical Cores)
for Release 8.5 = 2 (with 600 MHz reservation)
for Release 8.6 = 2 (with 800 MHz reservation)
SO ALL IN ALL
1) switch off the vmware.change the reservation
2) switch on.upload the cop file on all nodes
3) upload the upgrade software
4) upload the lic file for cucm 8.6
Are the above steps corrects?
could someone confirm that?
we use CUBE6000
Many thanks
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
  • IP Telephony
2 ACCEPTED SOLUTIONS
Hey Chrysostomos,
I did an upgrade from 8.5 to 8.6 within VMware and it worked without any changes to the OVA template / VM machine.
As long as the COP file is installed the upgrade should be successful. I recommend that you take a full VM snapshot of the machine(s) before attempting the upgrade, this way you can roll back quickly if things go bad!
The process includes a Red Hat upgrade so lots of coffee required.... watching the progress bar ;-)
Check re the license as I'm sure you have to submit a PAK request. www.cisco.com/go/license
Good luck with your upgrade.
You DO need to change the VM settings (because as mentioned, there is a RHEL upgrade) and that is explained in the RNs which are in the link you pointed to. If you create a VM with 8.5(1) OVA and one with 8.6(1) OVA you'll see this difference.
Upgrading to Unified CM 8.6(1a)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_6_1/cucm-rel_notes-861a.html#wp1944944
Step 3 Change the Guest Operating System to Red-Hat  Enterprise Linux 5 (32-bit).
I'd recommend you to review the whole section in the RNs before attempting the upgrade.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hey Chrysostomos,
Thank you Jamie for your answer
java
java
Hi java
Thank you for the explanations
Also congratulations  for the hall of fame
chrysostomos
2513
