Upgrade CUCM 8.5 to 8.6
Hi to all,
 I have a customer who would like to upgrade its CUCM from 8.5 to 8.6 (I don't know why he wants it), somebody knows when I do a upgrade from CUCM 8.5 to 8.6, all the configuration remains and is valid for the new version? Is a minor upgrade?? How many improvements have the 8.6 about 8.5 version??
In the cisco site, all documentation for the 8.5 version is the same than the 8.6 version, but I didn't find any documentation for this purpose. All the documentation that I can find is about the upgrade from 4.X or 3.X version.
Somebody can help me?? If you could leave me a link to a document or website I would thank you a lot.
Thanks to all!!
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Hi,Yes, this upgrade does not
Yes, this upgrade does not result in any data loss. For information about new features and changes introduced in cucm 8.6, check the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_2/delta/delta862.html
Manish
Hi, Please refer to the below
Please refer to the below link:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_2/cucm-rel_notes-862a.html#pgfId-1944944
Venkatesh
VIP Purple
Hi Babi,it would be a minor
Hi Babi,
it would be a minor upgrade with  no requirement for licenses.Further, the configuration would remain intact after u do minor/major upgrade.
regds,
aman
VIP Purple
Hi Babi, you can refer the
Hi Babi,
you can refer the software compatibility matrix for upgrade paths or cop files if required.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
VIP Purple
[+5] to Aok for more detailed
[+5] to Aok for more detailed explaination.
regds,
aman
Manish
Venkatesh
Hi,Thanks, you help me a lot!
Thanks, you help me a lot!!!!
I wasn't able to find any documents....
Thanks a lot!!!
VIP Super Bronze
Babi,Please note that even
Babi,
Please note that even though this is a minor upgrade, this is a refresh upgrade and leads to long down time due to several server reboots. Recommended practice for this is as follows
  • Perform a DRS back up before upgrade
  • Track console of server to monitor progress of upgrade – IP KVM, HP ILO, or IBM RSA
  • Install the latest COP (ciscocm.refresh_upgrade_v1.1.cop.sgn) file to allow for successful upgrade and limit switch version after upgrade
  • To minimize downtime, upgrade Publisher or first node until completion and then upgrade first set of Subscribers or secondary nodes while leaving some nodes performing call processing
  • Select automatic Switchover to the new version
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
83
