Upgrade CUCM from 6.1 to 9.1 Business Edition
Hi all,
I have to upgrade a CUCM  actually in use from 6.1 on MCS 7828  to CUCM 9.1 on VMWARE ( Business Edition on UCS C220).
I want to know what is the best scenario to do for the upgrade?
thanks in advance
regards
Cham
1 REPLY
If you're a partner, see here
If you're a partner, see here the doc for 5K to 6K migration
https://communities.cisco.com/community/partner/collaboration/migration
Short answer, go to a version supported on ESXi (8.(0)2a+) on your MCS to migrate to UCS, then use BAT at any point in time you like to migrate the data.
java
if this helps, please rate
www.cisco.com/go/pdi
74
