Upgrade CUEAC version 9 to Attendant Console Advanced 10
I am running CUEAC 9.1 with CUCM version 9.1. My customer wants to upgrade the attendant console to version 10 advanced,  but keep CUCM at version 9. I see this is supported from the attendant console documentation I have read. I believe version 10 is a serverless offering. Is there the option to go version 10 on my current windows 2008 server(this is where version 9 is running) or does it have to be serverless. Is it possible to introduce high availability if I upgrade to version 10 advanced? I am finding it hard to find definitive documentation for this.
Derek
2 ACCEPTED SOLUTIONS
Serverless AC is CUACS, the
Serverless AC is CUACS, the one which requires a server is CUACA.
All the documentation is on Cisco.com, if you search attendant console advanced/standar
http://www.cisco.com/en/US/products/ps7282/tsd_products_support_series_home.html
Go thru the documentation and you'll get the answer to your questions. RNs and install guide.
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Purple
[+5] to Jaime. High
[+5] to Jaime.
High Availability is supported in Advanced version .You can refer datasheet
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-attendant-console/data_sheet_C78-731867.html
further, as mentioned by Jaime, you can refer release notes of Advanced and Standard version for Compatibility with Call manager & OS requirements .Advanced version is supported on VMWare.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuaca/10_5_1/release_notes/CUACA1051RN.pdf
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuacs/10_5_1/release_notes/CUACS10511543RN.pdf
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Attendant_Consoles
regds,
aman
java
VIP Purple
[+5] to Jaime. High
[+5] to Jaime.
regds,
aman
thanks Guys. Most helpful
Hiwhen upgrading the
when upgrading the attendant console client (from CUEAC 9 to CUACA 10)
Do the operators lose their speed dials, shortcuts etc they have already configured?
Hi I am running CUEAC
I am running CUEAC (enterprise Edition) 9. If I activate my UCSS to upgrade to 10 CUACA, do I automatically get entitled to use high availability or is a separate license required.  CUEAC 9 currently does not support high availability, only premium version does. I am hoping i get the ability to use HA automatically, as this is the reason I want to upgrade in the first place.
Derek
An HA license would have to
An HA license would have to be purchased separately when upgrading from CUEAC 9.1 to Cisco UAC Advanced version 10.
VIP Purple
Hi, [+5] to Mawindha.You can
[+5] to Mawindha.
You can refer the ordering guide which says
For Cisco Unified Attendant Console Advanced:
 License quantity should equal the number of users that need to use the system concurrently
 Cisco Unified Attendant Console Advanced also offers an optional High Availability (HA) license.
Purchase a quantity of 1 HA license for each Cisco Unified Attendant Console Advanced server you
wish to make redundant
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/uc_og-ucl_cucm_mcs_cer_CUxAC_cime_sme-edcs840769.pdf
regds,
aman
930
