UPgrade DUC client error?
Hi, I make the client update DUC 1.2.3 to 1.2.5, update it displays the following error "Setup could not find a file notes.ini" file, the notes client version is the version 8.5.1 installed the client installation is multi-user notes.
best regards
Jose Riveros
Everyone's tags (1)
Re: UPgrade DUC client error?
Hi Jose,
They may not be compatible. You could check the compatibility matrix (Link).
Hi Jason,
     Matrix was verified and confirmed that the client PC meets the minimum requirements to install 1.2.5 duc clients.
351
