Upgrade fail 6.1.4 - > 9.1.2 unable to locate partition 5 to use for
Hello Community, cisco support for upgrade szenario to install 6.1 in a Vmware. I start the customer enviroment CUCM 6.1.4 in a VMware 4GB RAM, 1 CPU, 80GB Harddisk. works well.
1. install refresh cop.
2. install 9.1.2 over os admin install/upgrade. upload works well. choose no reboot, because i must change to RHEL 5. Installation after first reboot works well. during the first reboot i saw on the cli " unable to locate partition 5 to use for . press ok"
thats all!
i am appreciate for any help.
THX Armin
HTH, please rate all useful posts and right answers.
OK, so is that during the actual install process??
Or once 9.1.2 is installed, you switched the partitions and then shut it down to change the OS??
Or you're trying to change the OS, BEFORE switching parttiions??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I try to explain the right state and position of the error message. I assume it is during the actual install process.
1. Install "Refresh COP File" version 1.2 is finish.
2. No reboot.
3. Choos Remote Update from sftp
4. CUCM 6.1.4 starts download 9.1.2 non bootable image (5GB) from sftp. Additional I open the CLI on Vmware to see what is going on.
5. After  download from sftp is finish, I choose w/ switch version and had it try w/o switch version and press next Installation is in process I see over the Webapage.
6. After automatically first reboot from CUCM, I saw in CLI "  unable to locate partition 5 to use for . press ok for Reboot".
Now it is in loop and come back all the time to this message.
Thanks in ahead Armin
What platform are you using??
I'd suspect an error with your storage due to that error.
java
java
Re: Upgrade fail 6.1.4 - > 9.1.2 unable to locate partition 5 to
Laptop Windows 7 SSD 512GB, 8GB RAM
VMware 7.0 Workstation, 4GB, 80GB 1CPU for 6.1.4 RHEL 4 32bit
Hi, still the same problem. I followed this guide starting on page 18 (see PDF)
https://supportforums.cisco.com/docs/DOC-35163
1. Choose Linux 3 32bit
2. Skip Step 3 because I have 6.1.4a
3. Install 6.1.4
4. Skip Step 5 and 6 because only one Server
5. Install Refresh Cop File 1.2
6. Restore Customer Data
7. Reboot
8. Start with Step 1 at page 19 and choose "Switch to new Version after Upgrade"
After time, in Installation Status Windows you see "Upgrade Complete" and the Server Restarts. In CLI you see the bootprocess and stops with this attached message. Also attached the Install log from the status window.
Any help are appreciate.
Thanks Armin
I did the procedure in my lab from 7.15 and 6.1.5 and got no problems, so, this must be something particular to your environment, I see you opened a case, unfortunately, you're not entitled for PDI services, you need one of these:
Collaboration (UC)
  • Advanced Collaboration Architecture
  • Master Unified Communications
  • Advanced Unified Communications
  • Express Unified Communications
  • Authorized Business Edition
  • Cisco Distributors
  • Cisco Systems Engineers
And your company holds none of the above
java
java
solved, see here
https://supportforums.cisco.com/message/4028361#4028361
565
