Upgrade failed on subscriber from 7.0.2 to 7.1.5
Hi expert.
I'm problem with upgrade from 7.0.2 to 7.1.5
I installed the unrestricted patch on both Publisher and Subscriber
I installed the upgrade on Publisher (without switchversion)
But I cannot intalled the upgrade on Subscriber, show me unkown error.
Can anybody help me with the analysis log?
Peterson
Harmit Singh
Hi Perterson,
I analyzed the logs and here is what I saw:
05/23/2010 11:59:40 CCMInstall|(CAPTURE) Sun May 23 11:59:39 2010 dbllib.getDataFromPub  DEBUG:  MD5SUM don't match calling os.remove to delete all the ontape_backup|<:DEBUG>
05/23/2010 11:59:40 CCMInstall|(CAPTURE) Sun May 23 11:59:39 2010 dbllib.getDataFromPub  DEBUG:  ontape_backup pulled from the pub is of a different version than running on this subscriber |<:DEBUG>
05/23/2010 11:59:40 CCMInstall|(CAPTURE) |<:DEBUG>
05/23/2010 11:59:40 CCMInstall|(CAPTURE) Sun May 23 11:59:39 2010 dbllib.getDataFromPub  DEBUG:  please reupgrade the pub, this will regenerate the correct backup of the version that subscriber is being upgraded to |<:DEBUG>
05/23/2010 11:59:40 CCMInstall|(CAPTURE) Sun May 23 11:59:39 2010 dbllib.getDataFromPub  DEBUG:  Install is going to fail now |<:DEBUG>
Could you please verify if the MD5 matches the one published on cisco.com? In all probability it may not. What you would need to do is:
++     Download the media again and verify the MD5.
++     Re-upgrade the Pub.
++     Upgrade the Sub.
Note: Kindly ensure DBreplication is good between the servers prior to the upgrade.
HTH.
Harmit.
I will try this...
thanks
Peterson
