upgrade firmware ip phone 7971g
quisiera me ayudaran para hacer upgrade de firmware a telefono 7971g con versión sccp70.5-0-3-0s y llevarlo a versión sccp70.9-2-1s
estoy trabajando con call manager 8.5.1 y el telefono no se registra arrojado el error "Load ID Incorrect"
gracias
Atte.Eduardo
1 REPLY
Hall of Fame Super Red
Hi Eduardo,
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 9.2(1) or greater, you must first upgrade your firmware to an intermediate version (8.3(3) - 8.5(2)) then upgrade to 9.2(1).
Note This section applies to the Cisco Unified IP Phone 7975G, 7971G-GE, 7970G, 7965G, 7962G, 7961G-GE, 7961G, 7945G, 7942G, 7941G-GE, 7941G, 7911G, and 7906G.
The following upgrade issues apply:
If you are currently running firmware earlier than 6.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you must first install an intervening 7.0(x) load to prevent upgrade failure. Cisco recommends using the most recent 7.0(3) load as the intervening load to avoid lengthy upgrade times.
If you are currently running firmware 6.0(2) to 7.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you can do so directly. However, expect the upgrade to take twice as long as usual.
Device packs are required to enable IP Phones in the Cisco Unified Communications Manager database. For Cisco Unified CallManager 4.2 and earlier, these device packs are required. For Cisco Unified CallManager 4.3 and Cisco Unified Communications Manager 6.0 and later, you must run the device pack and reboot the Cisco Unified Communications Manager server.
To access the device packs, follow these steps:
Procedure
Step 1 Go to the following URL:
http://tools.cisco.com/support/downloads/pub/Redirect.x?mdfid=278875240
Step 2 Log in to the Tools and Resources Download Software page.
Step 3 Choose the IP Telephony folder by clicking +.
Step 4 Choose Call Control > Cisco Unified Communications Manager (CallManager).
Step 5 Choose your Cisco Unified Communications Manager version.
Step 6 Choose Cisco Unified Communications Manager > CallManager Device Packages.
Step 7 Choose the device package.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_2_1SR2/english/release/notes
/7900_921SR2.html#wp42493
Cheers!
Rob
298
