Community Member
upgrade from 4.1(3) to 4.1(3)SR8
Hi all. I am going to be doing an upgrade soon on a site that is currently at CallMananger 4.1(3). They want to go to 4.1(3)SR8, so that they can support some new phones they have. Has anyone done this before? Id like to know if this is a simple upgrade, or if there are any potential issues people have seen in the past on this. Any advice appreciated.
3 ACCEPTED SOLUTIONS
Re: upgrade from 4.1(3) to 4.1(3)SR8
there's nothing special to it, install on PUB, then on SUBs.
be aware most of the times if what you're looking is support for new phone models then you need to install latest DevPack and not just the SR
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hye John,
No worries!
On the page you were looking at (that has CME,Unity Express etc.)near the top is this;
Software Delivery System
*New - Voice and Unified Communications is now available for download through the new delivery system.
To access Voice Software downloads, click here. (*click here)
This will take you to this area;
Tools & Resources> Download Software> Voice and Unified Communications > Cisco Unified CallManager Version 4.1 > Unified Communications Manager/CallManager Device Packages
Hope this helps!
Rob
hopefully it won't break:
http://tools.cisco.com/support/downloads/go/ReleaseType.x?optPlat=&isPlatform=Y&mdfid=278853938&sftType=Unified+Communications+Manager%2FCallManager+Device+Packages&treeName=Voice+and+Unified+Communications&modelName=Cisco+Unified+CallManager+Version...
if it breaks follow the path Rob provided
BTW: Thx for the message on my new star Rob, this week it was thursday AM shift so today i got some extra sleep hehe
java
java
java
java
Hi John,
Just to add a note to the great tips from Java (happy Friday Java +5 points :)
Have a look at the ReadMe to see what is involved with the upgrade. It is worth noting that the time needs to be factored in for all the IP Phones to upgrade their Firmware. You will also see what Device models are supported;
Cisco Unified CallManager Release
4.1(3) Service Release 8a
http://www.cisco.com/web/software/282074220/23393/ciscocm.4-1-3-sr8a-Readme.pdf
Hope this helps!
Rob
Community Member
Thanks guys, I appreciate it. One more question, where do I get the device packs that might go along with 4.1(3)?
Hi John,
Device Packages are located here (right close to the SR's);
Hope this helps!
Rob
Community Member
I think Im getting lost at this point:
I see alot of other things like srst, unity express, call connector, etc. But I dont see the Cisco Unified CallManager Version 4.1
Hye John,
No worries!
Hope this helps!
Rob
java
java
Community Member
Rob, Java, thanks guys. I appreciate your help.
205
