Community Member
upgrade from 6.0.1 to 6.1.1 - error There is not enough disk space in the c
HI
I am trying to upgrade the cisco unified manager from 6.0.1 to 6.1.1 via remote server ( FTP).
I received the following error:
There is not enough disk space in the common partition to perform the upgrade. Please use either the Platform Command Line Interface or the Real-Time Monitoring Tool (RTMT) to free space on the common partition."
so I do a "show status" and it shows that lots of spaces has been allocated as logging. how can i delete the log from there so that the call manager will have more disk space for upgrade?
kind regards
Rachel
Community Member
Re: upgrade from 6.0.1 to 6.1.1 - error There is not enough disk
I have not run into this myself yet... However I have heard the only way around this is to install from DVD.
Red
This is bug CSCsi91410.
Workaround:
Use SFTP (www.freeftpd.com) or use DVD drive.
My blog:
http://htluo.blogspot.com/
My book:
http://www.lulu.com/content/5552336
208
