05-29-2008 07:10 AM - edited 03-15-2019 10:57 AM
Hi all, trying to upgrade.
i.e. I go to OS Management on the browser, select upgrade, select DVD and / for the root, then NEXT.
It identifies the file, I select NEXT, then it comes back with the following:
[/usr/bin/sudo/usr/local/bib/base_scripts/upgrade_validate_file.shmethod=localsource_dir=/file_name=UCSInstall_UCOS_6.1.2.1000-13.sgn.iso] did not generate the appropraite result file.
now I did do the md5sum on the file and got the desired result, so i've no idea why it doesn't appear to like this.
Any ideas out there?
ta
Grant
05-29-2008 07:53 AM
Grant, did you merge the two ISO files and compare the md5 ?
05-29-2008 08:07 AM
Hi Sankar,
yes I downloaded both files then merged then ran the md5sum utility, got the right checksum.
I was wondering, when I downloaded the file I did it on a windows pc and ran the merge on it, then the md5sum and burned a dvd. however the servers are Linux. I assumed this shouldn't make any difference as its only a lump of data thats being merged, shouldn't matter what os is doing the merging, right?
05-29-2008 08:19 AM
I have had issues with merging files before. the md5 of individual files will match, but after combining, it wont match at all. I dont think the windows/linux issue matters, but the last time i did a 6.0 to 6.1 upgrade, i had to run it via CLI.
05-30-2008 02:58 AM
Found out what is was, I hadn't burned the image as an iso onto the disc, i'd done it just as a lump of data. Once burned as iso worked fine.
