Upgrade from 6.1.1 to 6.1.2
We have downloaded the two .iso files and merged them into one DVD compilation. Anyone that can easily describe how we should perform the upgrade in the easiest way?
Hall of Fame Super Silver
Re: Upgrade from 6.1.1 to 6.1.2
Follow the upgrade guide:
http://cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpch7.html
Either burn the iso to DVD or use sftp/ftp to install it, it's all outlinied in the above doc.
HTH, please rate all useful posts!
Chris
just to add something, the procedure to merge the files is in the readme, you should always go thru the file when downloading files from cisco
java
if this helps, please rate
java
www.cisco.com/go/pdi
DO NOT BURN AN IMAGE from the ISO file. You can use a DVD but you have to burn the ISO file itself onto the disc, not the image that it generates. This is 100% backward from what is stated in the OS administration guide.
There is no 6.x to 6.x upgrade kit available--the only available kits are 4.x/5.x to 6.x. DVDs ordered from Cisco WILL NOT WORK for upgrades from 6.x versions because they contain the files themselves and not an ISO. You must download the files, concatenate them and either burn the ISO file itself to a DVD (in "mastering" mode for Vista sufferers) or put it on an SFTP server.
The release notes contain no instructions beyond concatenating the downloaded file, and the OS administration guide says the exact opposite of what is true: "...you must create an ISO image on a writable DVD from the upgrade file..." Only the remote source upgrade section alludes to the .sgn.iso file. With regard to a DVD/CD upgrade, the guide is COMPLETELY WRONG and the release notes are silent, so please save your admonition to RTFM.
129
