Upgrade from 7.1.5 to 8
     I've finally received my licence for 8 and we're currently running on 7.1.5 which doesn't appear to support direct upgrades. Short of rolling back to 7.1.2 and losing any changes made in the last 3 months, does anyone have any ideas of an upgrade path to 8?
          Joe
  • IP Telephony
Hall of Fame Super Red
Re: Upgrade from 7.1.5 to 8
Hi Joe,
You are most correct my friend, there is no upgrade
path from 7.1(5) to ANY 8.0(x) version. The supported
upgrade path will be to CUCM 8.5 which should be released
before the end of 2010.
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Last I heard was November so it's around the corner.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks guys,
Given that the beta runs until the end of November, I'm not sure that FCS will be November. As for the upgrade I'm figuring a rollback to 7.1.2 and then figure out what I've changed since then . I really want to get CUPS 8 up and running to demo to customers (it's not the same in the lab).
Joe
272
