Upgrade from Cisco Unity Connection 7.x to 10.5
Hi everyone!
Is it mandatory upgrade from Unity Connection 7.1(5b) to Unity Connection 8.x, before upgrade to Unity Connection 10.5(1)?
2 ACCEPTED SOLUTIONS
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/release/notes/10_5_1cucrn.html#pgfId-1957559
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Alberto,You can refer the
Hi Alberto,
You can refer the following doc for this specific scenario
https://supportforums.cisco.com/document/12218881/unity-connection-upgrade-version-702-1051
Manish
java
Thansk Jaime !!
Thansk Jaime !!
Hi Alberto,
Manish
Thanks Manish, I will follow
Thanks Manish, I will follow this procedure
155
