Upgrade kit for CUCM 8.5 CM8.5-K9-UPG=
fuhrersk8
Level 3
Level 3
Hi guys!
     Ive received the upgrade kit for CUCM 8.5 with part number CM8.5-K9-UPG=  CUCM 8.5 Upgrade for PUT only. There is an upgrade DVD, an installation DVD. Does the installation DVD is for a full version install? The situation is the following, Im going to upgrade a CUCM 8.0 and a Unity 8.0 to 8.5, but I have third server that Im having problems to install it as the subscriber in version 8 because of secret password problem or communication with publisher. I already reseted the secret on Publisher but still the Subscriber is unable to establish trust with Publisher. Im planing to upgrade the Puiblisher and Unity to 8.5 and then do a fresh install of 8.5 into the third server but as a Subscriber. I want to be sure that with this upgrade kit I will be able to do a full instalation of version 8.5 on the third server as a Subscriber.
Thanks in advanced!
2 Accepted Solutions
Chris Deren
Yes, the DVD is a full install bootable DVD.
HTH,
Chris
Rob Huffman
Hi Nephtali,
Here is the bug you are hitting in relation to the Security password
CSCti18766 - Pwrecovery and set password user security result in inconsistent hashes
Description
Symptom:
After setting security password via pwrecovery, cannot add subscriber nodes to the cluster. They fail when contacting the publisher.
Conditions:
Particular security password values result in a different hash via pwrecovery.
Workaround:
None at this time.
Details
1st Found-in:                          (2)
8.0(3), 8.0(2.42011.1)
Status:
Fixed
Last Modified:
Feb 28,2012
Fixed-in:                          (5)
8.5(1.10000.26), 8.5(0.98000.38), 8.5(0.98000.18)
8.0(3.11001.3), 8.0(2.40005.1)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (9)
Cheers!
Rob
6 Replies 6
Chris Deren
HTH,
Chris
Thanks Chris!
Rob Huffman
Hi Nephtali,
Description
Symptom:
Conditions:
Workaround:
None at this time.
Details
1st Found-in:                          (2)
Status:
Fixed
Last Modified:
Feb 28,2012
Fixed-in:                          (5)
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
Thanks Rob.
fuhrersk8
Level 3
Level 3
I did applied the patch to the version 8.0(3.11001.3), resetted the secret once again but problem persists. Any other aspect to check besides ip connectivity, hostname and secret password match? Im going to upgrade to 8.5 but not sure if problem will persist. Thanks.
Rob Huffman
Hi Nephtali,
If it were me I would open a TAC case to get this resolved prior to upgrading
to 8.5
Cheers!
Rob
