Community Member
Upgrade my cme/cue, install language pkg
Hey Pros,
I want to upgrade my IOS, i think its pretty old now.(see infos bellow)
But when i go on "cisco downloads" i see several version of ios, (sp service, adv entreprise,...)
*which one should i take ?
*Do i need to install the ios + other features pkg?
*is it erase my configuration ?
*Also i want to install another language package, permit the multilinguage, how to proceed ?
thanks in advance
About Cisco CallManager Express
Operating System: Cisco Internetwork Operating System. Cisco IOS (tm) C2800NM
Cisco IOS Software: C2800NM-SPSERVICESK9-M
Software Version: 12.4(3h) / CME 3.3
Feature Package: IP|FIREWALL|VOICE|PLUS|SSH
Licensing Information
Default # personal mailboxes: 12
Default # general delivery mailboxes: 5
Maximum # configurable mailboxes: 17
Maximum message space (minutes): 6000
Maximum telephony ports: 8
Installed Packages: Installer (Installer application) 2.2.2
Bootloader (Primary) (Service Engine Bootloader) 2.1.2
Infrastructure (Service Engine Infrastructure) 2.2.2
Global (Global manifest) 2.2.2
GPL Infrastructure (Service Engine GPL Infrastructure) 2.2.2
Voice Mail (Voicemail application) 2.2.2
Bootloader (Secondary) (Service Engine Bootloader) 2.1.2
Core (Service Engine OS Core) 2.2.2
Auto Attendant (Service Engine Telephony Infrastructure) 2.2.2
Installed Languages: English language pack (English language pack) 2.1.3
Hall of Fame Super Red
Re: Upgrade my cme/cue, install language pkg
Hi Xavier,
The required steps are nicely listed in this doc;
Installing and Upgrading Cisco Unified CME Software
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00808777e0.html
This thread has a nice note from Paolo!
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde8b54/2#selected_message
Why don't you start by upgrading IOS to 12.4(11)XJ4, for CME 4.1. This seems to be a highly rated and stable IOS/CME combination.
12.4(11)XW2 - CME 4.2
12.4(15)T - CME 4.1
12.4(11)XJ - CME 4.1
From this doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
For CUE, Here is some related info;
CUE - Adding or Removing Languages
Installing additional languages or removing languages must be done in online mode only. You cannot add or remove languages using the boot helper except when you perform a complete installation of the Cisco Unity Express software.
Installing Additional Languages
Prerequisites
The following information is required for installing languages:
URL of the FTP server.
Restrictions
You are limited to 2 concurrent languages with an AIM-CUE module license
You are limited to 5 concurrent languages with an NM-CUE, NM-CUE-EC, or NME-CUE module license
From this good doc (with Step by Step);
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_installation_guide_chapter09186a008087723b.html#wp1109793
Here is what you need;
To download a language file for voice-mail prompts, go to http://www.cisco.com/pcgi-bin/tablebuild.pl?topic=281001346.
Have a look at the method listed at this link that detals changing the CUE Language without losing all existing data;
Frequently Asked Questions
I have a working system and I want to change the language (while saving all the data on the system). Which procedure do I need to follow?
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008064172a.shtml#qa1
Hope this helps!
Rob
Community Member
wow thank you so much for all these details!
One more question, i dont understand the difference between the types of IOS
ADVANCED ENTERPRISE SERVICES
INT VOICE/VIDEO, IPIPGW, TDMIP GW AES
IP BASE
etc....
on my conf list it seems i had SP SERVICES
so should i take
SP SERVICES
c2800nm-spservicesk9-mz.124-11.XJ4.bin
myconfig:
"Cisco IOS Software: C2800NM-SPSERVICESK9-M
Feature Package: IP|FIREWALL|VOICE|PLUS|SSH "
Also...
do i need to reinstall all the features and installed package?
thanks in advance.
Hi Xavier,
Yes, that should be good. Recommended Cisco IOS IP Voice or higher image;
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/products_qanda_item09186a00801af2c6.shtml
Hope this helps!
Rob
810
