Upgrade path OS
Hi there,
I was wondering if someone got a document about the path to upgrade the OS. My OS is Windows 2000.2.6. Any help will be highly appreciated.
1 REPLY
Re: Upgrade path OS
there is no upgrade path doc, simply look into the release notes of the version you want to go and it will tell what OS is required.
usually if you jump to 2000.2.7 you will be able to go to the latest releases, in any case just confirm before installing by reading the release notes of the target OS you want to install
java
if this helps, please rate
java
www.cisco.com/go/pdi
226
