Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Upgrade questions CCM 4.0(2) to 4.1(3)
Set to upgrade from 4.02 to 4.13 this weekend.  Checking the caveats a major one is
Important: Remove any call forwarding that is set on voice-mail ports that are used only for outbound calls and message waiting indication.
Where exactly to I disable these call forwards?
1 REPLY
Re: Upgrade questions CCM 4.0(2) to 4.1(3)
Under VM Port DN
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
130
