05-01-2007 02:54 PM - edited 03-14-2019 09:15 PM
Is it possible to upgrade a current Callmanager Server (Publsher) with new disks, that I' ve got more space available than I have right now?
I just made an upgrade of the server to 4.2.3 and I had problems with the disk space.
Peter
05-01-2007 04:20 PM
What is your current disk/drive setup? Mirrored drives, stripped...etc? 1 partition, 2 or more partitions?
05-01-2007 07:10 PM
Hi Mike
There are 2 18,2 Gig Disks and they are mirrored and there are 2 partitions as well.
Peter
05-01-2007 07:16 PM
Are both partitions full or are you having problems with just 1 partition?
I haven't tried it, but if you have a larger drive you could pull one of the mirrored drives and put in the larger drive. Let it re-mirror, remove the smaller drive and then use something like Partition Magic to resize the partition. As long as you pull a drive before that you will have a backup drive. Just a thought, but I'd see if anyone else makes any suggestions too.
05-01-2007 07:30 PM
Check out this post I found on another board: http://forums.viaarena.com/messageview.aspx?catid=20&threadid=77392
Pretty much what I suggested.
