Upgrade Time CM5
Trying to upgrade CM 5.04 to 5.04c in order to move to 5.1X. How long is the upgrade process supposed to take? Mine's been running for more than three hours. Last item in the log is backing up snmp something or other.
Green
Re: Upgrade Time CM5
upgrade should have finished already
refresh the page
which option you selected?
reboot after upgrade?
which is the last line of the install log?
Not sure what happened. Last night I ran the upgrade again and told system to reboot at completion and it did. I then installed 5.1.3-2000-3 and it appeared to die at one step. but when I came in this morning it was upgraded and working. Scary.
98
