Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Upgrade to 10.5 then downgrade to 10.0
Hi Folks, Due to a technical oversight, we ordered 10.5 software via PUT for an upgrade from 6.1.5 using PCD however, we can't use 10.5 as it isn't supported by  third party application but 10.0 is. Question is, as I have 10.5 media, could I upgrade to 10.5 using PCD then downgrade to 10.0 using the non bootable ISO from CCO?
Paul
No, you need 10.0 media for
No, you need 10.0 media for the upgrade
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks - thought as much.
72
