Upgrade to 6.1.3
Has anyone upgraded to 6.1.3? Is 6.1.3 a cumulative of all bug fixes in the 6.1.1 and 6.1.2 train?
Please let me know your thoughts on whether or not 6.1.3 will be a stable release. Any help appreciated. Tahnks
Jason
Re: Upgrade to 6.1.3
6.1(3) has some very important fixes in it and it is expected to be a stable release. I have already upgraded a lower environment system for one client to 6.1(3) on the release date and have not had any issues thus far.
Community Member
But what about if you want to upgrade 6.1.3 system to 7. What should you do then?
Should Cisco implement upgrade from 6.1.3 to 7? Can anybody answer me this question?
Green
Hi Jason,
Yes 6.1.3 includes cumulative fixes for 6.1.2
prety stable I would say.
Community Member
Point to note, You can not upgrade to V7 currently from 6.3, only 6.2 so if you are planning an upgrade may not be worth it as I had to downgrade prior to upgrade.
Community Member
How did you downgrade from 6.1.3? Its not letting me load the 6.1.2 version so I can upgrade to 7.0(2).
Did you just start from scratch and load 6.1.2.
Community Member
Hello, robray
I didn't clearly understood you post.
You want to say that there will be issues if I want to upgrade from CUCM from 6.1.3 to CUCM 7 by first downgrade from 6.1.3 to 6.1.2?
Community Member
With 7.0(2) it does say you can upgrade from anything above 6.0(1a) so the issue upgrading from 6.1.3 may now be resolved.
When you attempt the upgrade which I did via FTP it did say unsupported but that was to 7.0(1). As I had upgraded from 6.1.2 to 6.1.3 I was able to swap the active partitions back to 6.1.2 to upgrade to 7.0(1).
Community Member
I was wrong here - Looks like still no direct upgrade to V7 from 6.1.3 - http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40074
Community Member
What should I do If I wanted to upgrade from 6.1.3 to 7? Will Cisco implemetn solution to direct upgrade or it will be possible only after downgrade?
VIP Super Bronze
UCM 6.1(3) was released after UCM 7.0(1). Because of this, a direct upgrade is not possible. We expect the next release of UCM 7.x to support a direct upgrade. Whether they decide to release 7.0(3) or move directly to 7.1 has not been decided at this point.
Community Member
6.1.3a is now available
Hall of Fame Super Silver
You will need to wait for CM 7.1 if you want to upgrade from 6.1.3, 7.1 is just around the corner though.
HTH,
Chris
164
