Bronze
Upgrade to CUCM 7.1(5b)
Hi all, I'm running CUCM 7.1(2), is it possible a direct upgrade to 7.1(5b).
David
Re: Upgrade to CUCM 7.1(5b)
Yes, see here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp201999
However, the general consensus of most folks on the forum is that you'd be better served to go with 7.1(3b)SU2.
Hailey
Please rate helpful posts!
I wish it was easy enough to get the original media for 7.1.3 version, Cisco only ships out the 7.1(5b) version.
Bronze
Hi David, thanks for the info. Do you any suggestion about the upgrade, it is better using local DVD or FTP/SFTP(about this, do you have a recommended software).
Thanks again
David
Personally, I always use SFTP and a downloaded upgrade file from CCO unless for some reason (i.e., licensing) I would be required to order an upgrade kit. So, I'd suggest SFTP and using CopSSH.  We (my colleagues at NetCraftsmen)  use it exclusively and, so far, without any of the issues you read about here with other products.  Here is a blog my colleague put together on CopSSH and how to set it up.
http://www.netcraftsmen.net/component/content/article/70-unified-communications/700-which-windows-sftp-server-should-i-use-for-my-cisco-uc-appliance-how-about-copssh.html
Hailey
Bronze
Hi David, thanks a lot for your suggestion. I tried the upgrade from 7.1(2) to 7.1(5b) using SFTP and local DVD, but I receive the same error "An unknown error occurred while accessing the upgrade file".
I check the md5 (UCSInstall_UCOS_7.1.5.30000-1.sgn.iso  -  272eee358eeb4d50dc1986cb54bb21fa)
Thanks a lot
David
Silver
hello,
You will have to post the complete logs for us to suggest.
How long did the upgrade go before it failed?
Go to the RTMT tool>>trace collection>>collect files>> check the upgrade install logs>> select the range in which you tried the upgrade.
You also might want to have a look at the pre upgrade  tasks:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html#wp1179532
After looking at the upgrade logs we can suggest why it failed, ans what needs to be done next.
Kunal
Bronze
Hi, Kunal, thanks for your support, I copy the install/upgrade logs. The upgrade fails while the CUCM is accessing the upgrade file.
10/20/2010 09:26:43 file_list.sh|Starting file_list.sh|<:INFO>
10/20/2010 09:26:43 file_list.sh|Parse argument method=local|<:DEBUG>
10/20/2010 09:26:43 file_list.sh|Parse argument source_dir=/|<:DEBUG>
10/20/2010 09:26:43 file_list.sh|Parse argument dest_file=/var/log/install/downloaded_versions|<:DEBUG>
10/20/2010 09:26:43 file_list.sh|Unmounting /mnt/source incase it is mounted|<:DEBUG>
10/20/2010 09:26:43 file_list.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|Checking /mnt/source/ existence|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|List DVD directory /mnt/source/|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|List directory complete (0)|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|List file (pre-filtered):|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|(CAPTURE) UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|/usr/local/bin/base_scripts/filter.sh file=/var/log/install/downloaded_versions|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|List file (post-filtered):|<:DEBUG>
10/20/2010 09:26:44 file_list.sh|List file (pre-structured):|<:DEBUG>
10/20/2010 09:26:45 file_list.sh|List file (post-structured):|<:DEBUG>
10/20/2010 09:26:45 file_list.sh|(CAPTURE) |<:DEBUG>
10/20/2010 09:26:45 file_list.sh|success|<:INFO>
10/20/2010 09:26:45 file_list.sh|file_list.sh complete (rc=0)|<:INFO>
10/20/2010 09:26:49 upgrade_validate_file.sh|Starting upgrade_validate_file.sh|<:INFO>
10/20/2010 09:26:49 upgrade_validate_file.sh|Parse argument method=local|<:DEBUG>
10/20/2010 09:26:49 upgrade_validate_file.sh|Parse argument source_dir=/|<:DEBUG>
10/20/2010 09:26:49 upgrade_validate_file.sh|Parse argument file_name=UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
10/20/2010 09:26:50 upgrade_validate_file.sh|Unmount DVD|<:INFO>
10/20/2010 09:26:50 upgrade_validate_file.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
10/20/2010 09:26:50 upgrade_validate_file.sh|Determining upgrade type for UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:INFO>
10/20/2010 09:26:50 upgrade_validate_file.sh|Getting patch size for /mnt/source|<:INFO>
10/20/2010 09:26:50 upgrade_validate_file.sh|There is enough space on device to proceed.|<:INFO>
10/20/2010 09:26:50 upgrade_validate_file.sh|(CAPTURE) mount: block device /dev/cdrom is write-protected, mounting read-only|<:DEBUG>
10/20/2010 09:26:50 upgrade_validate_file.sh|(CAPTURE)   Free space : 83190435840|<:DEBUG>
10/20/2010 09:26:50 upgrade_validate_file.sh|(CAPTURE) Space needed : 9928910848|<:DEBUG>
10/20/2010 09:26:50 upgrade_validate_file.sh|Checking if isofilename exists on /mnt/source|<:INFO>
10/20/2010 09:26:50 upgrade_validate_file.sh|/mnt/source/isofilename does not exist|<:ERROR>
10/20/2010 09:26:50 upgrade_validate_file.sh|Unknown internal error|<:ERROR>
10/20/2010 09:26:50 upgrade_validate_file.sh|upgrade_validate_file.sh complete (rc=1)|<:INFO>
10/20/2010 09:26:51  Installation CANCELLED
10/20/2010 09:26:51 Killing background processes
Thanks a lot
David
Hi David,
Did you put the iso file on the DVD or did you burn the image?
Cedric
This is what I'd recommend....download the ISO files of the upgrade from CCO.  Merge them as per usual process.  Put them on the SFTP server (presumably CopSSH).  Let's assume you create a user called "sftpuser".  Put the file in the home folder for sftpuser.  Conversely, you can rip the ISO to disk and store in the same location.
Don't forget to follow the pre-upgrade instructions (such as installing the COP file for unrestricted upgrades/installs).
Then do an SFTP upgrade.  When you do the path will be:
/home/sftpuser/
Then the login user will be sftpuser (or whatever user you created) and the password for that user.
Hailey
Bronze
Hi Cedric and David, I really appreciate your help.
To response Cedric.I put the ISO file in the DVD.
When I use SFTP, I received the following error: Error encountered: An unknown error occurred while accessing the upgrade file. MD5 Hash Value:
I will download the file again and I let you know.
Thanks a lot for all you assistance.
Best regards
David
Hi David,
You should burn the image so that the files in the iso get extracted to dvd rather than having the iso file as a single file on the dvd.
This is where the SFTP upgrade is different, ie: there you just put the iso file on your SFTP host.
Can you try again? If you're md5 checksum is identical to what's on cco, you shouldn't need to download again.
Cheers,
Cedric
Just a comment re. upgrading via the network.
Unless there are serious security concerns I normally use FTP rather than SFTP to transfer the upgrade image as it seems to take alot less time (I would guess at 30%).
This can be a big help if you have limited time to complete the upgrade and cannot install the image prior to the change window. I tend to use Sysax Multiserver which was recommended on here.
http://www.sysax.com/server/index.htm
It is friendlier than CopSSH but is a chargeable product ($97)
Bronze
Hi all, thanks to everyone for the suggestions. I use FTP Sever (FileZilla) for the upgrade and finally it shows as completed.
I will switch to the new version in a few hours.
Thanks again
David
Thanks for closing the loop David.
Great news!
1439
