Upgrade to CUCM 8.x
I want to upgrades a cluster of MCS7835H2-K9-CMC1 (1 CUCM publisher, 1 CUCM Subscriber) from version 7.0.1 (7.0.1.11000-2) to 8.x in a productions environments.
In a lab environment (VMware ESX 3.5), I tried to upgrade CUCM Publisher from version 7.0.1 to 7.1.2 but without success (the screen stuck in some phases of installation process).
What is the recommended path to upgrade from 7.0.1  to 8.x ?
It’s possible to make  a direct upgrade?
To make a major software upgrade from version 7.x to version 8.x , It’s sufficient if I have  on ESW contract for software licences?
Thanks.
1 ACCEPTED SOLUTION
Upgrade to CUCM 8.x
Switch either via CLi using
utils system switch-version
Or under the OS where you did the upgrade.
Switch PUB, wait until it fully comes up and then start switching SUBs one at a time.
Yes, if the CUCM version has a newer FW version unless you configure it otherwise they'll upgrade
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Upgrade to CUCM 8.x
You can review the upgrade paths depending on what version you want here:
Supported Cisco Unified Communications Manager Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
Supported Servers for Releases of Cisco Unified  Communications Manager (including Business Edition 3000 / 5000 / 6000  and Session Manager Edition) and Cisco Intercompany Media Engine
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
java
java
Upgrade to CUCM 8.x
I read this documents.
I have a CUCM Cluster version 7.0.1 , 1 Publisher, 1 Subscriber.
I start the upgrade procedure to version 7.1.2 on both servers.
This is the situation right now  on both servers:
7.0.1 active version
7.1.2 inactive  version
I want to switch the version 7.0.1 to version  7.1.2.
What is the correct procedure on the cluster to boot to new version 7.1.2?
If i switch the version 7.0.1 to new version 7.1.2  the cisco phone reboots and upgrades to new version?
Thanks.
Upgrade to CUCM 8.x
java
java
Upgrade to CUCM 8.x
Please clarify for me this aspect.
How to make a major software upgrade from version 7.x to version 8.x ?
What is the procedure?
Thanks.
Upgrade to CUCM 8.x
If you've done one upgrade on Linux appliances you've pretty much done them all. They're all the same procedure.
The same you did from 7.0(1) to 7.1(2) is when doing any major/minor upgrade.
java
java
Upgrade to CUCM 8.x
But, i need a software feature licence ordered via PUT?
The ESW contract cover this or i need UCSS?
Gold
Upgrade to CUCM 8.x
For major release upgrades (7 to 8) you will need UCSS as you will need to request a new license through PUT. This is true for all major relaese upgrades. ESW on its own will only get you minor release upgrades.
HTH. Barry
565
