Bronze
Upgrade to SRST 9
Hi Experts,
I need to upgrade the SRST from 7.1 to 9.0. Do I need to upgrade the IOS version or just the SRST. Could someone please send me the detail on how to do so.
MK
1 ACCEPTED SOLUTION
No, SRST-M is optional, as
No, SRST-M is optional, as for version
http://www.cisco.com/c/en/us/support/unified-communications/unified-survivable-remote-site-telephony/products-device-support-tables-list.html
java
if this helps, please rate
www.cisco.com/go/pdi
SRST is the same as CME, it's
SRST is the same as CME, it's directly tied to the IOS version, you cannot upgrade them independently.
There are many guides on cisco.com on upgrading IOS
java
Bronze
Thanks Jaime,That's what I
Thanks Jaime,
That's what I thought. It seems we need to use SRST Manager as of version 9.0, is that right? In order to have SRST version 9.0 we need to move to 15.2, right?
MK
java
28
