Upgrade VG224 to latest IOS
I wanted to upgrade my VG224 to the latest ios.  Does someone have step-by-step on how to do it using HyperTerminal?
  • IP Telephony
1 REPLY
Hall of Fame Super Silver
You should be able to find this information in any CCNA book. Basically:
  1. download the IOS file you want to use from CCO download page
  2. put the file into a tftp folder on your PC
  3. telnet to the VG224
  4. issue "copy tftp slot1"
  5. follow the prompts to enter the ip address of your PC, filename, etc
  6. wait
  7. reload
You may need to delete current IOS if you do not have enough space on the device, you can check by issuing "show slot1"
HTH, please rate all useful posts!
Chris
1252
