upgrade
Hi every one
I want to upgrade cucm 6.1.1 on MCS to 10.0 on UCS  can any one just give me any good advice and some small tips  i already read  some document and check in google but nothing clear , there is to many way ,
Thanks.
VIP Gold
You should use PCD for this
You should use PCD for this migration. Bellow is the link which having nice discussion on it.
https://communities.cisco.com/thread/42888
Suresh
Hall of Fame Super Silver
Indeed PCD is the way to go,
Indeed PCD is the way to go, upgrade your current version to supported CUCM that can be used by PCD which I think is either 6.1.4 or 6.1.5, and then use PCD to get to 10.0 or 10.5. Follow PCD admin guide for specific instructions.
Chris
Because you're actually
Because you're actually supposed to review all that info before you do the actual upgrade, you're supposed to review the RNs, the upgrade guide, and new and changed docs for your target release.
All the info is on cisco.com -> support -> all products, then in the tree you choose the path to the product, or type the name in the search box.
java
if this helps, please rate
www.cisco.com/go/pdi
46
