Community Member
Upgraded from CM 7.1.5 to 8.6.2 - Startup Warning
This is in relation to another discussion I started for the upgrade itself, but since the upgrade is done and this is a different issue, figured I'd start a new discussion.
As the title implies, I just finished an upgrade from 7.1.5 to 8.6.2. My data is all there and working fine in 8.6.2, however each time I reboot the VM's I get the two attached warnings before the VM's will start up.  Anyone seen these before?  How do I get rid of them?
I was thinking about doing a DR backup of my 8.6.2, recreating two new 8.6.2 vm's and restoring to those.  I was thinking maybe something didn't quite go right in my 7.1.5 to 8.6.2 upgrade. ??
You need to start by mentioning the details of the upgrade and HW being used.
Was 7.1(5) on VM?? if so, that's not a supported path for upgrading to VM supported version and most likely the cause of the error.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Green
As you are upgrading to 8.6.
I think you need to dowload and run
ciscocm.refresh_upgrade_v1.1.cop.sgn
This is an OS patch that is required before the CUCM upgrade can be run.
Please see the read me file on the dowload page
Alex
Regards, Alex. Please rate useful posts.
Community Member
I ended up having to built up new machines and just used the Import/Export option under bulk admin from the old servers to the new.  Problem solved.
264
