upgrading a Cius
What is the process to upgrade a Cius?   I cant seem to figure it out. The CCO download is a ZIP file and it has a few files in.  Do you leave the ZIP and upload that to CUCM from the OS page or?   Its a little odd it seems like.  Thanks!
1 ACCEPTED SOLUTION
upgrading a Cius
There's a cop file you download, it's the exact same thing as with a phone. Latest one is:
cmterm-cius.9-2-3-143.cop.sgn
Download it, install it via OS admin and CIUS should download it. Once it's downloaded you'll get a message a new FW is going to be installed and to reboot now or delay it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
upgrading a Cius
java
java
upgrading a Cius
Thanks Java... yeah,  i saw the COP file and didnt put 2 and 2 together.  I kept looking at the firmware ZIP file and couldnt figure out what to do with it.
upgrading a Cius
where do you find the OS admin? Is this option on the table?
upgrading a Cius
CUCM OS admin and I have no idea what table you're talking about.
java
java
upgrading a Cius
Sorry, for my mistake. I meant to ask if the cius tablet can be update directly or does the tablet gets os updates directly from call manager.
upgrading a Cius
CIUS is just like any other phone, you install the FW on CUCM and it will download it from there.
java
java
upgrading a Cius
635
