Upgrading from Callmanager 4.1(3) to Unified Communication 6.1(2)
shamugalu1
Can we do a direct upgrade from CM 4.1(3) to UCM 6.1(2. If yes, is there any hardware compatibility issues currently all servers are HP hardware platform running Windows 2000, how about Operating system (Windows 2000/2003? or Linux?) how about compatibility with Unity 4.2(1)?, IPCC 4.0(4)are there any issues? Any pros and cons for going 6.x?
5 Replies 5
Jaime Valencia
have you checked the compatibility matrix???
Supported Cisco Unified Communications Manager Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1168414
you will use Linux, since you do not mention the server model check the link:
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
for unity make sure to install the latest TSP.
SCCP Compatibility Matrix: Cisco Unity, the Cisco Unity-CM TSP, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
Cisco Unified Contact Center Express
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1569721
javalenc
if this helps, please rate
java
javalenc,
This information is very helpful and I appreciate it.
Thanks.
Hi shamugalu1, let me know if your upgrade was successfull because i am going to do the same job.
Jose
Jose,
I haven't done yet, we have a lot of other applications that depends on the current CCM so I'm still evaluating dependencies and compatibilities.
Oh, ok shamugalu1. Please let me know how it is going.
Best wishes on that, Jose
