Upgrading from ccm 3.3(4) to 3.3(5)
aboelhouwers
I'm looking for a upgrade guide from ccm 3.3(4) to 3.3(5) but no success. The only upgrade guide is "Upgrading Cisco Callmanager 3.3(5)". This document only mention a upgrade from 3.3(3) but not from 3.3(4).
Can I use this guide for the upgrade?
Rgrds
2 Accepted Solutions
jbarcena
Level 9
Level 9
Yes, you can use that guide since is pretty much the same, that is why you can not find one guide for CCM 3.3(4). The unwritten rule in Cisco is that if we did not update the document is because is not needed.
//Jorge
Rob Huffman
Hi Aad,
We did this upgrade using the doc that you are referring to. We never did find a 3.3(4) to 3.3(5) version. Here is the one we used along with some other helpful docs;
Upgrading Cisco CallManager Release 3.3(5) (Updated 7/11/2005)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a0080379983.html
Release Notes for Cisco CallManager Release 3.3(5)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a008034775b.html
Troubleshooting Guide for Cisco CallManager, Release 3.3(5)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00803b3b4b.html
Cisco CallManager Documentation Guide for Release 3.3(5)
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/doc_gd/dg335.htm
Hope this helps! And good luck!
Rob
jbarcena
Level 9
Level 9
//Jorge
Rob Huffman
Hi Aad,
Rob
Rob and Jorge,
Thanks a lot, this was very usefull.
Rgrs
Aad
