Community Member
upgrading from ccm4.2 to 6.1 problem
Hi everybody,
I upgraded my ccm (publisher and  subscriber) from 4.2 to 6.1  with cisco DMA.
after that i send the .lic file generated by cisco DMA ti cisco licensing and they send me the new license.
I uploades the licese to my new call manager and after the reboot I have message warning say's that i should upload the software license or the call manager service wil not run.
when I look to license report the ip phones and node license is uploaded and the software license is missing.
I dont have any third party software .
when i try to run the call manager manually after some second after that  the service show not running.
Please show me what should I do?
Hall of Fame Super Red
Re: upgrading from ccm4.2 to 6.1 problem
Hi Faycal,
***You should have received a PAK with the 4.x to 6.x Upgrade Media***
Use this procedure to obtain a software feature license:
Procedure
Step 1 Navigate to the License Registration web tool at http://www.cisco.com/go/license.
Step 2 Enter the Product Authorization Key (PAK) that you received with your Cisco Unified Communications Manager upgrade.
Step 3 Click Submit.
Step 4 Follow the system prompts. You must enter the MAC address of the Ethernet 0 NIC of the first node of the Cisco Unified Communications Manager cluster. You must also enter a valid e-mail address.
The system sends the license file to you via e-mail by using the e-mail address that you provided. To view the contents of a software feature license, refer to "License File Contents" in the Cisco Unified Communications Manager System Guide.
Step 5 You must upload the software license file to the server with the matching MAC address that you provided in Step 4.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b02licfu.html#wp1067359
Hope this helps!
Rob
Community Member
Hi rob,
thank you very much for your response, !but !i dont receive any pak number from cisco to upgrade from 4.2 to 6.1.
what should I do to receive it?
the pak number come in the MCS box or single box?
Thank you
Hi Faycal,
You are most welcome my friend
The PAK# should have come with the upgrade media
DVD's. Either on a piece of white paper or perhaps
a sticker on the box. Have a look for the small box.
Cheers!
Rob
Community Member
Hi ROB,
I found the box with the software license.
the last thing I will say to you is thank you very very much, really you are the best of the best.
Salutations
Hi Faycal,
Great work my friend!
Thanks for your very kind words
Cheers!
Rob
Community Member
Hi everybody.
I have upgraded my ccm 4.2 publisher and subscriber to cucm 6.1 and after that i send the file .lic generated by dma to cisco licencing, I also register the two PAK of number to receive the the software licences. with the publisher mac address file:///C:/Documents%20and%20Settings/faycal.RABAHI/Bureau/ENI/Eni%20licenses/CCM20100103011147597.lic
I have uploaded to the publisher the
upgraded licenses
the new licences I purchased from cisco
the two licences I have received from cisco with the PAK number software claim
after that when I go to look for licence report in ccm node licenses i see unit authorized 4 unit used 2.
why do I have 4 unit authorized and 2 used, as I know i shoould have 2 autorized two used?
and the publisher is fonctionning correctly but when the ip phone register whith th subscriber there is many issues.
Please help.
278
