Upgrading from CUCM 6.1(3) to CUCM 6.1(5)
Is there a way to speed up the upgrade installation in a production environment?
In my lab, I installed 6.1(5) in the inactive partition the following order:
-          Publisher
-          TFTP
-          Subscriber (backup)
-          Subscriber (primary)
Then I switched versions the same order in ~10mins intervals. The entire upgrade took about 5hrs.
Can I download and install 6.1(5) on all four server’s inactive partitions at the same time? Or maybe Pub first then the rest of the servers? The upgrade will be done after hours.
Thanks!
3 ACCEPTED SOLUTIONS
Super Bronze
Re: Upgrading from CUCM 6.1(3) to CUCM 6.1(5)
You can install the servers concurrently, but the subscribers will not allow the install to start until around 20 minutes into the install on the publisher (i.e. after the image has transferred and the actual install starts, + 20 minutes).
Obviously you'll want to select the option to NOT reboot automatically - if the publisher install then fails your subs may complete OK and reboot to the new version before the publisher which you won't want...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hall of Fame Super Red
Hi Percy,
Just to add a reference to the great tips from Aaron (+5 points "A")
Here is some info on "Parallel" upgrades
http://www.ciscosystemsnetwork.net/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.pdf
Cheers!
Rob
You can upgrade the PUB to 6.1.5 and start Subs and TFTP at the same time to upgrade to 6.1.5 version.
Here is the Documentation on that
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html#wp1179699
Sri Gudavalli
Super Bronze
Aaron
Hi Percy,
Cheers!
Rob
Sri Gudavalli
Thanks a lot guys… very good information!
456
